    • On the Floor
Rexroth CKK Ball Screw Actuators Raise Performance for Wind Turbine Builders
By Patrick Curran | August 24, 2009
Tewkesbury, UK — Trio Motion Technology has added a SERCOS II digital drive interface to its new MC464 Motion Coordinator range. The MC464 SERCOS interface allows OEMs and automation systems integrators to benefit from advanced 64-bit multi-axis motion and machine control performance, and include application matched drive and motor technologies from a wealth of SERCOS equipped products available from many manufacturers.
The SERCOS interface is one of several digi
The TrioBASIC multitasking programmin
Users may also choose the industry standard IEC 61131-3 option for PLC programming with PC based tools for Ladder Diagram and Structured Text along with Instruction List, Function Block Diag
SERCOS applicati
Trio Mo
www.triomotion.com
< ###################################### UPDATE designworld05052012_posts s
On
The design of AMET welding equipment — and the role of linear motion technologies — is largely dictated by the techniques required to create massive wind turbine towers that can be around 90 meters high (close to 300 feet). During a weld, while the bulk of the equipment remains stationary, the weld head constantly moves small distances along at least 2 axes, both along and across the seam. A linear control actuator mounted at the end of a horizontal arm determines the motion of the weld head.
AMET’s goal was to create a cost-effective, dependable welding system that could perform accurate longitudinal and circumferential submerged arc welding. One of the most important challenges, however, was to assure smooth and precise (within 1/100th of an inch) control of
AMET also wanted linear motion elements that offered good strength (dynamic loads in exc
The compact CKK design, light in weight but durable and strong, makes machine assembly smoother and easier. “We knew that other linear motion solutions couldn’t give us
Another important feature leading to better and faster machine production is the fact that CKK 20-145 modules are complete, prepackaged systems, with dual ball rails and a ball screw
Download the c
Bosch Rexroth
Filed Under:
Actuators, Ballscrews • leadscrews, Green engineering • renewable energy • sustainability, Energy management + harvesting, LINEAR MOTION, Motion control • motor controls
    • On the Floor
