RFMW Links Telemakus Attenuator Video
By WDD Staff | July 1, 2013
RFMW (San Jose, CA) provides access to a video overview of the Telemakus, LLC series of USB Controlled Digital Attenuators. Using the TEA4000-7 as an example, the video steps through the functionality of the device by using its built-in GUI. The TEA4000-7 is a laboratory-quality, 7-bit Digital Attenuator with 31.75dB range in 0.25dB steps. The attenuator is fully terminated at all ports with a return loss better than 20dB from 50MHz to 4GHz. The Telemakus TEA4000-7 is among the smallest USB controlled microwave attenuators available on the market. An SMA male connector at port 1 and female connector at port 2 allow for easy interconnection with other Telemakus products or DUTs. Features include:
  • USB type A, allowing direct connection to a PC or via a USB extender cable.
  • 0.5GB of flash memory contains all the installation files, data sheet and test results.
  • Windows-based user interface allows simple control of the attenuator including a ramp function.
  • Compatible with common ATE software.
For more information, visit www.rfmw.com.
