RHINO PSV “Value Series” dc power supplies
By Leslie Langnau | January 17, 2019
RHINO PSV “Value” series DIN rail power supplies are available in a wide selection of voltage and wattage ranges. 5V RHINO DC supplies are available in 15 and 25-watt ratings with 12 V supplies at 48 W. 24 Vdc supplies are available in 30, 50, 100, 120, 240 and 48 0 W; and 48 V supplies are rated up to 120 W.
15 to 100 W models, in ultra-compact plastic housings, have an efficiency rating of up to 89.0%, a full power operating temperature range from −10°C to +55°C and are NEC Class 2 / Limited Power Source (LPS) certified.
120 to 480 W RHINO power supplies have a metal housing, provide full power from −10°C to +50°C and efficiencies up to 88.0%. These models have a built-in constant current circuit for reactive loads.
RHINO PSV series dc power supplies are UL/cUL recognized, CE approved and have a three-year warranty.
Also added are universal battery control modules that provide uninterruptible 24 Vdc bus voltage and offer battery protection for over voltage, deep discharge, short circuit and reverse connection. Alarm outputs indicate input, output and battery conditions.
AutomationDirect
www.automationdirect.com/dc-power-supplies
Filed Under: Power supplies, MOTION CONTROL
Tagged With: automationdirect
