A new line of right-angle mounting plates provides easy assembly of slides and tables with their unique design. All mounting surfaces are milled flat to 0.05 mm while they are perpendicular to 0.1 mm, thus making it easy for users to mount and assemble.
The right angle mounting plates can be used in conjunction with any of the manufacturer‚’s Techno slides to build XY or XYZ positioning systems. The plates are complete with numerous through holes on a 25, 50 or 100-mm grid. The plates are available in five sizes, with wall thicknesses ranging from 12 to 15 mm for resistance to larger forces and vibrations.
TechnoAutomation
www.technoautomation.com
Filed Under: Linear motion • slides, Motion control • motor controls
