Right-angle Spiral Bevel Belt Drive from WITTENSTEIN (alpha)
By Miles Budimir | June 11, 2010
With long service life and high power density, the alpha LPBK+ right-angle gearboxes provide advantages as a mechanical add-on to servo drive trains.
Wittenstein_alpha_LPBK
Offering flexible design and available as standard in a food-grade version, the alpha LPBK+ is the low cost alternative which still guarantees maximum return. By taking the LPK+ right-angle gearbox and adding a pulley drive, Wittenstein has created an integrated solution with ultra-compact design and easy motor mounting.
Optimized for linear drives and available with flexible output variants, the LPBK+ can improve not only low-duty application designs but is also available in IP64 for food-grade applications. With a space savings of more than 40% compared to a conventional drive solution for linear applications, this product brings cost and space savings to your design.
Wittenstein
www.wittenstein-us.com
Filed Under: Drives (servo) + amplifiers, Gears • gearheads • speed reducers, Linear motion • slides, Mechanical, Motion control • motor controls
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
