Stafford Manufacturing Corp. offers a standard line of rigid shaft coupling adapters that can be modified to solve a wide range of shaft mating problems.
Stafford Rigid Coupling Adapters feature a standard clamp-type female end that attaches to an existing shaft and a male output shaft. Both ends are machineable by the factory or end-user to match customer requirements, and they come in bore sizes from 1/8” to 8” I.D., with shafts up to 8” O.D., and lengths up to 4 ft., depending upon bore size.
Available in steel with a black oxide finish, stainless steel, and aluminum, Stafford Rigid Coupling Adapters can be supplied with keyways and other I.D. modifications to the clamping end and the output shafts can be produced in threaded, tapered, keyed, and hex and square configurations. Applications include all types of machinery and conveyor drive components.
Stafford Rigid Coupling Adapters are priced according to material, size, and configuration. Price quotations are available upon request.
www.staffordmfg.com
Filed Under: Couplings, MECHANICAL POWER TRANSMISSION
