Rigid shaft couplings come in many configurations
By Mike Santora | December 18, 2024
Venmark InternationalKeeping your products in front of the WorldA broad line of rigid shaft couplings that feature over 500 standard items to solve a wide range of mechanical design challenges has been introduced by Stafford Manufacturing Corp. of Wilmington, MA.
Stafford Rigid Shaft Couplings feature over 500 standard part numbers including 1-pc, 2-pc, and 3-pc designs with straight-through or stepped bores, with or without a keyway; machined from aluminum, steel, stainless steel, and brass. The line also includes Precision Sleeve couplings that incorporate the Accu-Clamp design with an integral self-centering clamping feature at each end for mating two shafts with zero backlash.
Offering high-strength, low-profile, heavy-duty, and precision sleeve styles, Stafford Rigid Shaft Couplings come in round bores from 1/4 I.D. to 2-in. I.D. and metric from 6mm to 50mm, depending upon the part and material. Precision Sleeve couplings come in 1/4” to 1″ bore sizes to fit hex, square, and threaded bores and maintain < 0.001 TIR concentricity while in use.
www.staffordmfg.com
Filed Under: Coupling Tips
Tagged With: staffordmanufacturingcorp
