Ringfeder releases GWE 5117 servo-coupling for hollow shaft connections
By Mike Santora | June 8, 2021
RINGFEDER-elastomer-jaw-coupling-imageRINGFEDER has recently released its GWE 5117 series of elastomer jaw servo-couplings, featuring a new hub design. With its partially slit hub located directly under the jaws and two screw clamps, this model eliminates radial loads on the shaft and achieves uniform power transmission. This hub design also prevents premature wear and system failure.
Designed for hollow shaft connections, the GWE 5117 servo-coupling is equipped with an expanding mandrel for friction-locked torque transmission. It features a spider element that is available in solid standard form, minimizing movement and achieving longer life, or drilled through the center.
For convenience, the coupling comes with a slightly shorter design for compact use cases. It also provides easy accessibility with its interactive hub QR code that links to instructions.
Ringfeder
ringfeder.com
Filed Under: Coupling Tips
Tagged With: Ringfeder
Ringfeder — Dynamical torsional stiffness: some couplings need finer tuning
PTDA onProduct Information Exchange
PTDA Transmissions: Lessons from the Pandemic past can shape the future
Shaft collars and couplings feature wide choice of standard bores
