Rino Mechanical’s RW5 Miniature Gearbox
By Miles Budimir | July 13, 2009
The miniature Rino RW5 is made in the USA and is a helical gearbox that is made from a CNC machined aluminum block housing. It offers dual bronze bearings for shaft support, stainless hardened single piece worm/input shaft and stainless output shaft. It is designed for 24 hour per day operation.
The RW5 is 1.5” by 1.5” by 1.58” and has a torque rating to 12 inch-lbs. Ratios from 1:1 to 4:1 are standard and are stocked for immediate delivery. Input speeds to 5000 rpm. The RW5 is easily modified to fit customer requirements.
rino mechanical
www.rinomechanical.com
Filed Under: Gears • gearheads • speed reducers, Mechanical, Motion control • motor controls
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
