Rino Planetary Gearboxes
By Design World Staff | November 18, 2008
The low priced PGC series of low backlash and robustly built planetary gearboxes have 5 arc-minutes of backlash as standard and can be supplied with 1 arc-minute. The PGC series can have ratios from 5:1 to 10,000:1. They are IP55 rated. The construction is substantial and they are designed for 24/7 operation.
The Rino PGC series can also be supplied with shaft input. Customizing such as different diameters, different lengths shafts can also be done easily.
rino mechanical
www.rinomechanical.com/gearbox_planetary.htm
Filed Under: Gears • gearheads • speed reducers, Motion control • motor controls, Motors (gearmotors)
Tagged With: rino mechanical
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
