The made in USA miniature Rino RW8 gearbox with NEMA 23 input flange has ratios from 1:1 to 120:1 and torques to 40 inch-lbs. Input speeds to 5000 rpm. The RW8-NEMA23 is easily customized to meet customer’s special needs. Available from stock.
The RW8-NEMA23 is made from a CNC machined aluminum block housing, dual ball bearings for shaft support, stainless hardened single piece worm/input shaft and stainless output shaft. It is designed for 24 hour per day operation.
Applications include: food machinery, semiconductor processing, packaging machinery, medical diagnostic equipment, and all sorts of usual and unusual applications.
Rino Mechanical
www.rinomechanical.com/gearbox_miniature.htm
Filed Under: Gears • gearheads • speed reducers, Mechanical, Motion control • motor controls
