Sunnyvale-New, compact IDEC RJ relays come with plug-in PC board terminals and switching currents to 16 A. They also use a unique return spring mechanism, eliminating unnecessary weak points and increasing electrical conductivity and service life.
The relays come in 8, 12, and 16 A switching currents with an operational life of 200 K cycles and a mechanical life of 50 million cycles. Both SPDT, SPDT-NO, DPDT, and DPDT-NO configuration types are available.
Correlating sockets can be DIN-rail, panel, or PCB mounted. The DIN-rail/panel mount socket has IEC finger-safe terminals, where the coil and contact terminals are on opposite sides of the socket. The PCB mount socket allows for quick replacement, eliminating the need to re-solder.
IDEC RJ relays are UL recognized, CSA certified, VDE approved, and CE marked in compliance with IEC 61810-1.
For complete specifications or additional information, please contact IDEC Corporation at 1-800-262-IDEC (4332) or visit www.idec.com/usa.
About IDEC
Headquartered in Osaka, Japan, IDEC Corporation is a global manufacturer known worldwide for its reliable control and automation products. In the United States, IDEC has over thirty local sales offices to assist customers with choosing the right switches, relays, power supplies, PLCs, O/Is, sensors, and more.
For additional information, visit www.idec.com/usa.
IDEC Corporation
1175 Elko Drive
Sunnyvale, CA 94089-2209
Tel: (408) 747-0550 / (800) 262-IDEC (4332)
Fax: (408) 744-9055 / (800) 635-6246
:: Design World ::
Filed Under: Relays
