    • Subscribe!
RJ22 Bifurcated Contact Relays from IDEC
By Patrick Curran | November 14, 2011
Compact general purpose relays available in new bifurcated contact models are great as input devices for a variety of controllers including PLCs and Smart Relays used in the micro processing industry.
RJ22 relays are available with low signal switching bifurcated contacts for increased contact reliability, reduced contact bounce and switching low currents and voltages (dry circuits).These models have a maximum contact rating of 1amp at 250V AC, while maintaining a minimum switching load of 100uA 1V DC, allowing you to use this relay for dry circuit switching needs. With the shortest width on the market RJ bifurcated contact relays are durable, compact and available with plug-in or PCB terminals.
RJ22 Bifurcated contact relays from IDEC
Plug-in terminal relays have a non-polarized green LED indicator available (except on the simple type), utilizing IDEC’s unique light-guide structure. Diode, reverse polarity diode, and RC circuits are also available with peak inverse voltages of 1000V
Like the rest of the RJ family, RJ22 PCB bifurcated contact relays have been manufactured with attention to even the smallest details. Using our automated manufacturing technologies, an innovative design was utilized in the internal construction of moving parts ensuring the highest-quality, reliable relays. This includes a unique return spring structure eliminating unnecessary weak points, allowing for increased electrical conductivity and longer service life. Both DPDT and DPST-NO contact configuration types are available in a flux-tight structure.
RJ Plug-in and PCB Terminal relays (with bifurcated contacts) are UL recognized, CSA certified, VDE approved and CE marked. Correlating 2-pole sockets include multiple features for ease-of-use and can be DIN rail, panel or PCB mounted.
IDEC
www.IDEC.com/relays
Filed Under: Networks • connectivity • fieldbuses, PLCs + PACs, Relays
Tagged With: idec
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
    • Subscribe!
