Oriental Motor is pleased to announce the introduction of our new RKII Series Stepper Motor and Driver Packages with Built-in Controller (Stored Data) Type and Pulse Input Type.
The New RKII Series is an ideal and affordable solution for demanding requirements and is available with a built-in controller (stored data) type driver or pulse input type driver, for the same price. The RKII Series utilizes our new motor technology, reducing heat output with the motor, allowing it to run up to 104°F (40° C) cooler than the conventional stepper motors. This offers significant benefits, including 100% torque utilization with no compromise. Designed with the step angle selector, switching from 1.8° or 0.9° packages is as simple as setting the dial. For greater torque requirements, 3 new and improved geared motors are available from our spur (TS) gear, our planetary (PS) gear to our harmonic (HS) gear. All feature improved performance and lower pricing.
The new RKII Series products are available in 42 mm (1.65 in.), 60 mm (2.36 in.), 85 mm (3.35 in.) and 90 mm (3.54 in.) for geared type. Electromagnetic brake type and encoder models (built-in controller types only) are also available.
The RKII Series’ key features are:
- Easy to wire with motor connectors and driver connectors
- Low heat generation
- Low vibration
- Step angle can be set (pulse input type)
- Energy efficient
- Spur, Planetary or Harmonic gearheads available
Oriental Motor
http://orientalmotor.com/products/stepper-motors/index.html
Filed Under: Motors • stepper, Motion Control Tips
