RockStar ModuPlug terminal block modules with PUSH IN connection technology re-invents control cabinet wiring
By News Staff | January 11, 2021
The innovative terminal solution in the RockStar ModuPlug connector frees up space in the cabinet and reduces the time needed for installation. Using the individual modules, combine all the necessary functions for power, signal, data and pneumatics transmission in a single interface. The modules reduce the amount of space required and cut costs as compared with fixed-pole inserts and other modular plug-in connector systems.
The frames and modules can be installed and integrated into HDC housings with the IP65 and IP68 protection classes. You can even use RockStar ModuPlug in existing applications without the need to make system adjustments.
You save installation space, weight and costs: choose now between four different module widths. The halved pitch size allows twice the number of module slots in the frame. The reduced pitch separation creates more functionality in the same installation space. The innovative design of RockStar ModuPlug offers several benefits: a two-point fixture allows assembly and disassembly without tools. The fixed locking position provides for stability, meaning the modules can be assembled faster and easier. Incorrect connection is avoided through special round and rectangular coding.
Quickly and easily configure your individual plug-in connector online. The RockStar ModuPlug Online Configurator enables fast and easy compilation of frames, modules, contacts and accessories using drag & drop. Visit https://bit.ly/3o1IScU to configure your RockStar Moduplug.
Weidmuller
www.wiedmuller.com
Filed Under: Terminal blocks
Tagged With: Weidmuller
