Rockwell Automation introduces new on-machine drives
By Heather Hall | April 7, 2022
Rockwell Automation announces the release of its new Allen-Bradley Armor PowerFlex AC variable frequency drives for industrial motor control applications. The on-machine drives provide quicker installation, simple commissioning, and predictive maintenance.
As an on-machine solution, the Armor PowerFlex drives move controls and hardware out of a cabinet and onto the machine, closer to the application. This can help industrial companies simplify machine designs and minimize costs and time to deploy. The drives are also designed for harsh environments, where reducing installation time and cost are most critical.
The smart drives include an embedded EtherNet/IP dual-port switch, which provides fast collection of real-time data. The drives also monitor component life, allowing users to predict and schedule component replacements to help avoid costly unplanned downtime.
“Manufacturers can expect greater efficiency and productivity when using the new Armor PowerFlex drives, which have built-in technology that’s smarter, safer, more secure and easier to apply than other solutions on the market,” said Joe Azzolina, global product manager, Rockwell Automation. “Armor PowerFlex drives can reduce time-consuming tasks within the machine lifecycle. They can also help users realize greater profitability as part of a decentralized, zero-cabinet design approach.”
The Armor PowerFlex drives give users a motor control solution that replaces multiple components for easier integration into automation systems. The drives are available in standard and safety models. Both options provide built-in, dual-port EtherNet/IP and CIP Security functionality, and the safety option provides advanced safety functionality.
The safety model of the drive is designed for applications that require functional safety. It offers integrated CIP Safety and supports integrated and hardwired safe-torque-off (STO) or safe-stop-1 (SS1) safety functions. With integrated STO or SS1, no additional external safety monitoring or control components are required. Additionally, using the Armor PowerFlex drive with Allen-Bradley GuardLogix PLCs and encoders enables advanced safe-speed functions.
To help strengthen cybersecurity in industrial operations, the Armor PowerFlex drive is CIP Security capable. When implemented, CIP Security helps fortify a control system by providing data authenticity, integrity, and confidentiality. This helps defend against the risk of someone remotely accessing a network and acting maliciously.
You may also like:
  • Faulhaber-evocortex
    Autonomous navigation – with millimeter precision from Faulhaber
  • Logo_Standard
    Red Lion Controls acquires MB connect line GmbH
  • How to calculate duty cycle and what it means for…
  • faulhaber-hihg-dynamics-precision
    Small linear motor modules and axes as modular system from…
  • Screw drives see new uses in robotics, other applications
Filed Under: Drives (ac) + VFDs + starters
Tagged With: rockwell, Rockwell Automation, rockwellautomation, Allen Bradley of Rockwell
Condition-Monitoring-2_DE-no-key-compact-web-rgb
NORD condition monitoring for predictive maintenance
nordac-pro-family-web-rgb
NORD Drivestystems NORDAC PRO variable frequency drives.
siko-factory-floor-image
How positioning drives can help automate your production lines
Mitsubishi-FR-D700-VFD
Mitsubishi Electric VFDs and custom engineering
