Rockwell Automation’s new FLEX 5000 I/O Modules
By Mike Santora | August 19, 2019
FLEX-5000-Safety-IO-ImageNew Allen-Bradley FLEX 5000 safety I/O modules can meet the needs of producers in process and heavy industries that require fixed field-wiring terminations or both vertical and horizontal I/O mounting in their distributed safety applications.
The three new FLEX 5000 safety I/O modules provide distributed safety I/O for the
Allen-Bradley Compact GuardLogix 5380 and GuardLogix 5580 controllers. The safety modules can be combined with FLEX 5000 standard I/O modules to achieve integrated safety and control in one distributed I/O platform.
The modules offer safety reaction times as fast as 4.5 milliseconds to help designers create smaller, simpler and less expensive smart machines and equipment. They also offer extensive diagnostics to help users easily identify faults based on real-time data.
The safety I/O modules are TÜV certified for use in fail-safe applications up to SIL 3 and PLe, Cat. 4. They can operate in extreme environments and be directly connected to copper and fiber networks. They’re also available with conformal coating options for added protection against environmental stresses.
In addition to the new safety I/O modules release, the FLEX 5000 EtherNet/IP adapters now support the Parallel Redundancy Protocol (PRP) network standard. This Ethernet topology is a way for designers to create a redundant network infrastructure that has high availability and helps minimize downtime risks.
Rockwell Automation
ab.rockwellautomation.com
Filed Under: Controls (not motion controls)
Tagged With: rockwellautomation
Micro Controllers and Design Software optimize smart machine design
Watlow’s POWERSAFE medium voltage thermal system
ReeR MOSAIC safety controller components
CLICK PLUS serial communication option slot module and 2-slot CPUs
