Rogers Corporation (NYSE:ROG) will exhibit and present a white paper concerning Thermal Conductivity at the upcoming DesignCon 2012 conference and exhibition. DesignCon (www.designcon.com), scheduled for January 31 through February 1, 2012 at the Santa Clara Convention Center (Santa Clara, CA), is one of the electronic industry’s key meeting places for printed-circuit-board (PCB) designers.
Rogers’ circuit-materials expert Mr. Al Horn, Associate Research Fellow, is scheduled to speak at 11:05 AM on January 31, 2012, with his presentation, “Measurement and Modeling of the Effect of Laminate Thermal Conductivity and Dielectric Loss on the Temperature Rise of HF Transmission Lines and Active Devices.” The session should be of particular interest to designers concerned with dissipating heat in large-signal circuits.
Representatives from Rogers Advanced Circuit Materials Division will be on hand at Expo booth #810 to offer guidance on the use of the Company’s high-performance PCB materials, including Theta® and RO4000® LoPro™ materials.
High-performance PCB materials are a specialty from Rogers Corporation’s Advanced Circuit Materials Division.
Rogers’ halogen-free Theta materials are engineered for outstanding mechanical and electrical performance in high-speed digital circuits. With a coefficient of thermal expansion (CTE) of 50 ppm/°C in the z-axis, they have about 30% less expansion, across the same temperature range, than standard FR-4 for improved reliability of plated through holes (PTHs) in multilayer circuits. The low dissipation factor of 0.0118 at 1 GHz ensures that Theta materials preserve signal integrity in the most challenging digital circuit designs. Theta materials feature a dielectric constant of 3.90 at 1 GHz. In addition, these dependable laminates support RoHS-compliant manufacturing processes and meet UL-94-V-0 level flammability requirements.
RO4000 LoPro circuit materials are a low-profile copper foil option available on the RO4000 series that helps designers significantly drive down insertion loss and improve signal integrity for ATE, wireless, and networking applications. This low cost enhancement to the RO4000 series of dielectric materials is fully compatible with FR-4 fabrication processes and lead-free assembly temperatures. These laminates achieve low PIM values, which are critical for antenna designs and feature a low z-axis coefficient of thermal expansion (CTE) over a wide temperature range for reliable plated-thru-hole performance in multilayer circuits.
Rogers Corporation
www.rogerscorp.com
Filed Under: Semiconductor, Materials • advanced
