    • On the Floor
Rogers to Show High Performance Circuit Materials at Satellite 2013
By Stacy Combest | March 5, 2013
Rogers Corporation will be showcasing its high performance circuit materials for commercial and military satellite communications (satcom) electronic applications at the upcoming Satellite 2013 Exhibition.
The Satellite 2013 Exhibition will take place on March 19-21 at the Walter E. Washington Convention Center, Washington, DC. More than 350 companies will be exhibiting at this major satcom event, including more than 45 first-time exhibitors. Representatives from Rogers Advanced Circuit Materials Division will be available at Booth #4122 to answer questions and provide insight into the optimum use of the Company’s high performance circuit board materials, including RT/duroid® 6035HTC high-frequency laminates, light-weight RT/duroid 5880LZ circuit materials, and 2929 bondply material for fabricating multilayer circuits.
RT/duroid 6035HTC is a ceramic-filled, polytetrafluoroethylene (PTFE) composite material designed especially for high frequency, high power applications, such as antenna beam forming networks and power amplifiers for satcom systems and wireless cellular communications networks. With a relative dielectric constant of 3.50 at 10 GHz, the circuit material achieves minimal dielectric loss by merit of a low dissipation factor of 0.0013 at 10 GHz. The high-thermal-conductivity (HTC) fluoropolymer composite contains a unique filler system that enables excellent thermal conductivity of 1.44 W/m/K, with low drill wear compared to competitive offerings.
Rogers-1
Rogers RT/duroid 5880LZ PTFE based composite also features a unique filler, resulting in a low-density, light weight material well suited for airborne and satellite communications antennas, point-to-point digital radio antennas, and light weight feed networks. RT/duroid 5880LZ circuit materials combine a low relative dielectric constant of 1.96 and low dissipation factor of typically 0.0019, both in the z-axis at 10 GHz, for usable performance to Ku-band frequencies and beyond. These laminates can be easily cut, sheared, and machined and boast a low density of 1.4 g/cm3.
Rogers 2929 bondply is an unreinforced thermoset resin-based thin film adhesive system ideal for constructing reliable, multilayer circuits. It has a low dielectric constant of 2.94 in the z-axis at 10 GHz, with a low loss tangent of less than 0.003 also in the z-axis at 10 GHz. Well-suited for creating multilayer circuit boards with many of Rogers’ high-performance composite dielectric materials, including Rogers RT/duroid 6000, RO4000®, and RO3000® Series laminates, 2929 bondply materials are based on a proprietary cross-linking resin system that makes the adhesive system compatible with sequential bond processing techniques.
Rogers Corporation
www.rogerscorp.com
Tagged With: Rogers
Comments
  1. xx says
    March 6, 2013 at
    Artificial Christmas tree: pros and cons The Christmas tree go lolita clothing to Christmas as the sch nen gifts that are placed to the Christmas Eve under the tree. The children have a large mother of the bride pant suits delight with homemade or purchased Christmas ornaments to decorate the local Christmas tree, this ritual ‘ mother of the bride outfits the anticipation on the gro en Christmas Eve. However, before it is so far, many families are wondering whether they should set up a real or an artificial Christmas tree.Pros and cons of artificial Weihnachtsb umeAn artificial Christmas tree not needed and can also have any allergies sen foreign, because just allergies are increasing. cheap evening dresses the tree must not sp ter be disposed, but he will be packed just back in its box and robe de mariee pas cher next year it can be made up again, just like the purchased or whatabeautifullife review layering Christmas decoration. please vist:http://www.whatabeautifullife.com.The cost for a fresh Christmas tree this no longer incurred which naturally protects the household budget. Also ch. like the j annual search for a suitable real Christmas tree, which naturally protects the nerve. Depending on the quality, an artificial Christmas tree can whatabeautifullife reviews hold up to 10 years. The risk of fire is significantly lower than at a natural Christmas tree, because as soon as this anf to dry depends on, here clearly increases the risk of fire. The only disadvantage of artificial Weihnachtsb is trees, that they not have a scent of forest, but thanks to various room sprays or scented candles, can here to be helped. The prices for the sprays and candles k you can compare with Aldi Nord offers.What you in the purchase of artificial Weihnachtsb trees should be awareIf you opted for an artificial Christmas tree have, is when you purchase on the quality t to pay attention and not primarily on the price. The Aldi Süd offer here a small overview. An artificial Christmas tree made of polyethylene natural looks like a tree which is made of PVC. The polyethylene B ume are also safer, because they are somewhat refractory such as PVC-B ume. read more:http://www.whatabeautifullife.com.
    • On the Floor
