Diecast enclosures now come with color-coding
By Lee Teschler | April 8, 2021
Color-coded trims are now available as options on ROLEC’s aluCASE premium diecast aluminum enclosures for industrial electronics. These tough, elegant and versatile housings can be installed anywhere – on walls, machines, bulkheads and desktops.
The trims, which cover the lid and mounting screws, are now optionally available in rolecred (RAL 3020), blue (RAL 5017) or anthracite (RAL 7016), in addition to the standard window gray (RAL 7040). Separate screw channels enable aluCASE to be mounted ‘lid closed’ to protect the seal and electronics.
The lid is recessed to accommodate a membrane keypad, product label or front plate. Hinges and/or integrated lid supports are available on most sizes to keep the lid attached to the base when the enclosure is open. Two sizes (6.29×3.54×2.36 in and 5.51×4.33×2.36 in) are available with a transparent lid. Inside, there are screw bosses for installing PCBs, mounting plates and rails.
The robust aluCASE is available in 29 sizes from 2.95×1.96×1.29 in to 16.92×11.81×4.72 in. The standard color is window gray (RAL 7040). The housings are rated to IP 66 and IP 67 protection classes as standard. IP 69K is also available on request. Prices start at $32.
Options and accessories for the aluCASE include a console adapter (3.93 or 7.87 in) for desktop use; exterior hinges (with no visible outer fixing screws); anodized aluminum trims instead of the standard polyoxymethylene (POM) trims; key lock access (for added security) and a corrosion-proof coating (azure blue RAL 5009).
The ROLEC aluCASE can be supplied installation-ready. Customization services include: CNC machining, custom colors (painting or powder coating), printing, engraving/laser engraving, RFI/EMI shielding, membrane keypads and assembly.
ROLEC Enclosures Inc., 3000 Old Pond Road, Bridgeville, PA 15017, (888) 658-5774, E-mail: [email protected], https://www.rolec-usa.com/en/enclosures-accessories/alucase/
Filed Under: Cabinets • enclosures • control panels • DIN rail, MOTION CONTROL
Tagged With: rolecenclosures
