Hinged-lid enclosures for industrial electronics include transparent window display option
By Lee Teschler | December 5, 2022
Hinged-lid enclosures for industrial electronics are now available in eight sizes – either with or without a transparent window for displays.
Weather-resistant polyDOOR (IP 66) enclosures are candidates for challenging industrial and outdoor applications where equipment must be inspected or serviced regularly – such as processing, rolecmachine control, safety monitoring or marine electronics. These easy-access GRP (UL 94 V-0) enclosures are perfect for applications where chemicals are a risk. Cleverly designed integrated hinges allow the lid to be removed in a few seconds. The lid is locked with polyamide fixings – either standard slotted screw heads, triangular or square heads (to prevent tampering), or hand screws for rapid access. Inside there are threaded pillars for mounting PCBs, terminal rails and component assemblies.
Robust polyDOOR is now available in eight sizes from 5.51×4.72×3.94 in to 12.60×7.87×4.72 in. The standard color is similar to RAL 7032 pebble gray. Accessories and options include the choice of lid fixings, external mounting brackets, a silicon gasket, mounting plate, cable glands, cross rails, and DIN rails for terminal block assemblies.
ROLEC can supply polyDOOR fully customized. Services include CNC machining, digital printing of legends, logos and graphics, and assembly/installation of accessories.
ROLEC Enclosures Inc., 3000 Old Pond Road, Bridgeville, PA 15017, (888) 658-5774, [email protected], www.rolec-usa.com/en/enclosures-accessories/polydoor/
Filed Under: Cabinets • enclosures • control panels • DIN rail, MOTION CONTROL
Tagged With: rolecenclosures
