Rollerball Deburr™ Tool from Mate Precision Tooling
By Miles Budimir | December 22, 2010
Anoka, MN – Mate’s new Rollerball Deburr™ tool eliminates burrs and secondary operations. It’s the ideal solution for eliminating time consuming burr removal on punched parts.
Designed to deburr mild steel, stainless steel, and aluminum sheet material in any thickness, the Rollerball Deburr tool does the burr removal automatically and quickly as part of the punching process. No off-line, manual burr removal needed. No special off-line tools.
Mate-Rollerball-Deburr-Tool
Mate’s Rollerball Deburr is designed for Thick Turret and Trumpf Style applications. The new tool incorporates Mate’s proprietary Rollerball technology that uses the extended programming capabilities of punch presses operating in the x and y axis with the ram down.
Using a special ball in both the upper and lower part of the tool, the Rollerball Deburr pushes the burr away creating a slight radius on the punched edge. Smooth to the touch, the deburred edge is consistent and has a finished, esthetically pleasing appearance. All part contours can be processed with the Rollerball Deburr tool, including small, tight corners.
Mate-Rollerball-Deburr-Tool-2
Available for thick turret or Trumpf Style press applications, RollerBall Deburr comes as a complete set, including springs for adjusting tension appropriate for the material being punched.
“The Rollerball Deburr tool delivers exceptional value to the punching process,” reports John Galich, Mate marketing manager. “It’s fast and eliminates manual operations by allowing the punch press to do the work. Rollerball Deburr is yet another innovative Mate product that helps fabricators lower their operating costs and improve their piece part quality.”
MATE PRECISION TOOLING
http://www.mate.com/rollerball
Filed Under: Machine tool industry + subtractive manufacturing, Mechanical
Finalists announced in Mechanical category for the 2019 LEAP Awards
keysight
Gallery: Auto technology on display at the Automotive Testing Expo 2019
Death of the shadetree mechanic?
EXAIR offers high-capacity quality HEPA vacuum
