Rugged, reliable bearings are essential to ensure the reliable continuous operation of agricultural machinery in the field. Adverse environmental conditions – mud, dust, impacts, stone chippings and water – take their toll on machines and their components. These components must be designed to withstand such operating conditions and be protected as effectively as possible from environmental influences. As agriculture is becoming more intensive, machines are also expected to offer ever increasing performance and endurance; the rolling bearings – which have many applications in agricultural machinery – must keep pace with this development. Austrian manufacturer NKE offers a range of special-purpose products with a particular focus on application-specific, ready-to-use bearing units – the so-called Agri Units.
With Agri Units, NKE has come up with a generic term for bearing units designed for use in agricultural machines that require a rotating union between a disc-shaped tool and its mounting arm. Whereas producers of agricultural machinery previously often had to buy and assemble up to ten separate components, Agri Units represent a single part in the form of a fully assembled bearing unit. This means a cost saving, not least through a gain in efficiency, since purchasing, storage and spares inventories are limited to just one component and no prior assembly is needed.
The first step was to develop a rugged bearing unit for use in disc harrows with a disc diameter of up to 650 mm (Fig. 1). The design, which is comparable with existing solutions of similar size, has a number of special features: an optimized internal geometry that maximizes load capacity and resistance to tilting moments; a high quality grease filling in a sufficiently high quantity for the operating conditions to ensure a long lubricant and therefore bearing life as well as good corrosion protection; a combination of seals to prevent dirt ingress into the bearing (Fig. 2). In addition to the current standard version, NKE can adapt the unit’s external geometry to allow customers to integrate the unit into existing designs or tailor it to new applications.
The second application in the field of Agri Units is for seeding discs and for liquid manure spreader discs, whose application is similar to the harrow discs however of smallersize . These bearing units aim to replace the
conventional and often no longer satisfactory solutions consisting of deep-groove or double-rowangular-contact ball bearings with an all-in-one compact bearing unit. In addition to optimizing the internal structure, lubrication, sealing and ease of handling of the bearing units for disc harrows, the designers focussed on minimizing the unit’s
external dimensions.
Beside its new Agri Units product line, NKE offers standard and special bearings that also cover scenarios in agricultural technology in which bearing units cannot be used. This includes, for example, balers, power take-off (PTO) gearboxes and track systems. NKE also offers comprehensive technical support, including application consulting and the development of customer-specific solutions as well as commercial and logistic services, such as just-in-time (JIT) delivery.
NKE offers both standard and special bearings for all industrial applications. NKE’s core functions – engineering, product development, final processing of components, assembly, quality assurance, logistics, and sales and marketing – are centralised at its Steyr headquarters. In addition to product development and application engineering NKE provides a full range of technical services and training. NKE’s products are distributed through 15 international representative offices and more than 240 distribution outlets in over 60 countries.
NKE Austria GmbH
The post Rolling bearings for agricultural machinery appeared first on Bearing Tips.
Filed Under: Bearing Tips
