ROSS announces the introduction of its latest product, the Modular L-O-X® valve Air Entry combination. Combining three elemental products into one (filter, regulator and industry-leading lockout valve), this pre-engineered modular design offers many benefits.
Created with packaging, conveyor panels, and material handling applications in mind, the ROSS Modular L-O-X valve Air Entry combination conforms to the ANSI/PMMI B.155.1 — 2006 standard for packaging-related converting machinery. Also suitable for air entry applications, the Modular L-O-X unit consolidates multiple functions into one space-saving assembly and offers easy servicing.
Because many options are available with this product, it can be easily customized. While a reverse-flow, self-relieving piston-type regulator is standard in this design, a non-relieving option is also available. Theincluded filter has an internal automatic drain, but manual or float drains are also options. Additionally, MUFFL-AIR® silencers and EEZ-ON® valves (for gradual start up) are also available accessories.
Conforming to OSHA lockout standards, the L-O-X is easy to operate and is lockable only in the off position. Additionally, the L-O-X valve meets ANSI/PMMI B.155.1-2006 and ANSI B11.GSR standards with a full size exhaust port and a verification point for visible pressure release indication (pop up or pressure switches are optional).
Ross Controls
www.rosscontrols.com
Filed Under: Pneumatic equipment + components, Valves
