Servo coupling with high precision and standardized stub spindles
The backlash-free servo coupling (elastomer coupling) ROTEX GS P clamping ring hub is a two-part taper hub made of steel with an integrated clamping system.
This servo coupling is characterized by high-precision machining and resulting in good concentric properties and smooth running with high speeds.
Application ranges of our backlash-free servo coupling ROTEX GS P:
Applied in standardized stub spindles on multiple spindle heads acc. to DIN 69002
New high-performance spider for backlash-free servo coupling
KTR has a new spider in its product range which decisively increases the performance level of the backlash-free servo couplings type ROTEX GS with regard to temperature resistance and pressure resistance. The material is a newly developed “thermoplastic polyurethane” with a hardness degree of “52 Shore D” and a temperature resistance of up to 120° C. The main areas of application are servo-hydraulics and test bench technology.
KTR
www.ktr.com
Filed Under: Coupling Tips
