    • On the Floor
Rotor clip offers surface-friendly wave springs
By Michelle Froese | March 30, 2020
Rotor clip’s patented single-turn wave spring is designed with flat ends rest smoothly against mating assembly.
Engineers choosing springs for bearings typically prefer ones with a high axial load to reduce vibration and noise — and prolong bearing life. However, standard single-turn wave springs with a gap have sharp corners at the cut-off area of the spring ends.
These corners can scratch the surface of the bearing and mating parts when the waveform shows a steep incline, depending on the load specification. Ultimately, this debris can lead to failure of the bearing and an entire application.
Rotor Clip’s patented design solves this problem by flattening the ends of the spring so they avoid causing excessive wear that can damage an application.
As with all of Rotor Clip’s wave spring designs, there are no tooling costs for custom designs with this end feature.
Rotor Clip
rotorclip.com
Tagged With: rotorclip
  • Industrial automation accelerates with increased capital spending
    • On the Floor
