Transipillars, short for transitional pillars, provide a durable insulated spacer system for board-to-board stacking or board-to-chassis mounting. Made of studs and inserts molded in a nylon body, the combination of various lengths and metric thread sizes provides an extensive array of spacing options. The studs are available in stud/stud; stud/insert; or insert/insert configures with cylindrical or hexagonal body form and are made of galvanized steel and brass. Pillar lengths range from 13 mm to 64 mm, and can be customized.
Schurter Inc.
www.schurterinc.com/new_pems
Filed Under: Fastening + joining, Washers • spacers
