    • On the Floor
Rugged Magnetic Rotary Sensors/Encoders
By Design World Staff | November 17, 2008
RLS magnetic rotary sensors/encoders in new redundant models feature two independent sensors on one chip. Each sensor is totally isolated from the other and can be supplied with a separate power supply. The 2-in-1 units are available with 8-bit to industry-first 13-bit sensors. Each sensor can output SSI or incremental position information. Position error between the two sensors is better than ‚±1 bit.
The 2-in-1 units give redundant, critical-mission function on top of the solid-state strengths and compact size. They deliver high-resolution positioning (up to 8,192 count per revolution), speeds to over 30,000 rpm, and measurement accuracies to 0.4‚°, while withstanding temperatures from -25 to 125‚°C, and providing high resistance to shock, vibration, G forces and pressures. Used in applications ranging from medical scanners and aircraft controls to washdown, oilfield and subsea environments. All RLS magnetic encoders are RoHS compliant.
Renishaw Inc.
www.renishaw.com
Filed Under: Encoders (rotary) + resolvers, Motion control • motor controls
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
