Balluff is expanding their range of sensors for media-contacting temperature detection, in hydraulic power units for example. New is a temperature sensor with display, a temperature transmitter as well as a PT1000 sensor. The version without a display is especially compact and vibration-resistant, whereas the versions with the turnable and highly readable display offers high operating convenience and flexible installation.
Depending on the version, the BFT sensors provide PNP switching outputs, analog signals 0…10V /4…20mA or work as a PT1000 sensor. They are simple to install by threading into the process using a standard process connection with G- and NPT threads. Integrating them requires just a 4-pin M12 plug on the sensor.
Continuous monitoring of process media on machines and equipment contributes greatly to process security. Values that need to be maintained are pressure, level, and temperature. When, for example, in a hydraulic system you need to monitor the temperature of the hydraulic fluid, you can do this using Balluff’s BFT media-contacting temperature sensors.
Monitoring the temperature within the hydraulic loop guarantees correct fluid viscosity and thereby the best performance of a machine. Critical process conditions such as a temperature limit can be controlled directly via the switching output. An analog output provides continuous measurement results. The BFT temperature sensors also stand out when it comes to monitoring the cooling water, lubricants, and compressed air, making them suitable for a variety of applications.
Balluff
www.balluff.com
Filed Under: Sensor Tips
