A new family of stainless steel fork sensors with resistance to aggressive cleaning agents, chemicals, coolants or other media provides a viable solution for demanding environments in a variety of applications including hygienic.
These sensors are suitable for the packaging, food and beverage industries. These sensors can be used in other applications and industries that demand a robust housing to withstand the toughest environments.
The new sensors have normally open and normally closed outputs for easy integration into control systems. Multiple light sources — red light for easy setup or infrared light source for highly contaminated or environments with water or mist in the air — enables this sensor to be used in a multitude of applications. The pigtail with M12 connector and integral LED’s for output function and power on indication aids in fast and easy troubleshooting.
No alignment required, self-contained through beam sensor
PMMA optic lenses and stainless steel housing for food and beverage applications
IP67/IP69K housing for washdown
Complimentary outputs and optional light sources
Balluff
www.balluff.com
Filed Under: Sensor Tips
