    • Subscribe!
Rupture Disc Assembly for Wind Turbine Hydraulic Braking Systems
By Paul Dvorak | June 10, 2009
Liberty, Missouri — Continental Disc Corporation has introduced a new rupture disc assembly for wind turbine hydraulic braking systems. This rupture disc assembly protects equipment from damage and down time in the event of overpressure conditions.
Specifically designed for the hydraulic braking systems and yaw brake controls of wind turbines, the rupture disc assembly provides accurate and leak-free overpressure relief for the control valve/hydraulic accumulator system. The hydraulic braking system rupture disc assembly is available in a wide range of sizes, materials, and burst pressure ratings for use in wind turbine protection applications.
www.contdisc.com
Filed Under: Energy management + harvesting, Fluid power, Green engineering, Hydraulic equipment + components
Examining direct drive hydraulic maintenance
cylinder
Small, compact cylinder boasts large preload capacity
High modulus plastics for off-highway
Peninsular-Cylinder-top-10-coolest-things
Custom Peninsular Cylinder design named a finalist for “Coolest Thing Made in Michigan”
    • Subscribe!
