Saelig Introduces PicoConnect™ 900 Series Microwave/Gigabit Passive Test Probes
By Saelig Company, Inc. | October 25, 2016
Saelig Company, Inc. announced the availability of PicoConnect™ 900 Series Microwave/Gigabit Passive Test Probes, providing cost-effective testing of broadband signals or data streams up to 9GHz or 18Gb/s, including USB 2 & 3, HDMI 1 & 2, Ethernet, PCIe, SATA, and LVDS standards. Representing a price-performance breakthrough, these new high-performance test probes have less than 0.4pF tip capacitance and a ground-referred loading of 220 to 910 ohms. They are less invasive than the majority of existing and more costly probing solutions. To achieve measurement accuracies down to a few percent they are ratio-compensated for typical applications, such as the probing of transmission lines and ports between 40 ohms and 100 ohms (80 ohms to 200 ohms differential).
PicoConnect probes are characterized with a supplied 085 high-performance flexible coaxial cable, which achieves market-leading flatness and pulse response. The innovative in-PCB coplanar construction (patent pending) guarantees underlying microwave integrity as well as mechanical precision, strength and electromagnetic immunity. The passive design is inherently resistant to static discharge and demonstrates no significant overload recovery latency or error. The PicoConnect probes and multi-head probe kits are provided with solder-in accessories in a convenient carry and storage case.
Key Features
  • Suitable for use with any measuring instrument with 50 ohm inputs
  • PicoConnect probes permit high frequency oscilloscopes and spectrum analyzers to examine circuitry, backplanes, interconnects, and systems without disturbing their function
  • Offer probe division ratios of ÷5, ÷10 and ÷20 in twelve probe models
  • PicoConnect 900 Test probe Series is a set of interchangeable SMA(f) probe heads that can be used with any appropriate 50 ohm cable, or with accessories such as filters, dividers, amplifiers or further attenuation
Filed Under: Test + measurement • test equipment
mti
MTI
moog
