EXAIR offers a large selection of Safety Air Guns to suit your application. These include the VariBlast Compact Safety Air Gun, Soft Grip Safety Air Gun, Soft Grip Super Air Scraper, Heavy Duty Safety Air Gun and Super Blast Safety Air Gun, plus Back Blow versions of those guns. These Safety Air Guns use engineered air nozzles for high performance. Force varies from two ounces to 23 pounds, so you can choose the version that fits exactly what you need.
They are durable and comfortable to use. Each model uses an engineered Air Nozzle that provides superior performance by entraining large volumes of surrounding air. Safe operation is assured along with low air consumption and noise levels. Airflow that exits the nozzle cannot be blocked, as required by OSHA standard 1910.242(b). Chip shields, extension pipes and stay set hoses to use with the guns are available.
Nozzles used by the Safety Air Guns are available in stainless steel, PEEK plastic and zinc aluminum. Stainless steel air nozzles provide more mechanical wear resistance while withstanding corrosion and high temperatures. PEEK Air Nozzles provide protection from accidental impact with the target and outstanding corrosion resistance.
For more information about EXAIR’s large selection of Safety Air Guns, visit exair.co/58-SAG-Dir.
