Sanitary Thermowell/Removable Sensor from Omega
By Patrick Curran | March 1, 2011
This product can be used in clean-in-place systems allowing the sensor to be removed for calibration or service without disturbing your system. The sensor includes a 4-wire, Class-A, PT100 RTD with an M12 connector plug. The thermowell is 3-A approved, with wetted surfaces made from 316L stainless steel and a surface finish is 32 micro-inches or better. Temperature range of the sensor is -50 to 200 degrees Celsius (-58 to 392 Fahrenheit) and is compatible with 2, 3, or 4-wire RTD instruments. Perfect for food and dairy processing where Clean-in-Place or Sanitary Processing is required and also ideal for pharmaceutical manufacturing.
Omega Engineering
www.omega.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
