Fire Protection Pumping Systems
A global manufacturer of integrated pump solutions needed a reliable coupling for use on its fire protection packaged pumping systems installed in large commercial buildings. The couplings connect large capacity pumps to diesel drive engines. The challenges associated with this application were that the space envelope between the pump and engine was small and the pump and engine were positioned at different elevations creating misalignment issues. These conditions eliminated a traditional shaft-to-shaft, gear-type coupling from consideration.
The OEM contacted Ameridrives. After a detailed review of the specifications with the customer, Ameridrives engineers recommended SC universal joint driveshafts to meet the application requirements.
Ameridrives Americardan SC (short coupled) driveshafts are available in lengths ranging from 9.5 to 22.25-in. and can accommodate diesel engine ratings from 38 to 800 HP. These robust, compact driveshafts are designed specifically for short distance coupling applications with signi cant misalignment and high start-up torques. The driveshafts were shipped with stock bore companion anges. Short lead times allowed Ameridrives to meet the customer’s delivery requirements.
Ameridrives
ameridrives.com
Filed Under: Coupling Tips
