SCHNEEBERGER Inc. has announced the availability of the new SFERAX Type H.L. linear ball bearing — featuring high-quality engineering at a competitive price point.
Developed to support a linear bearing under high loads and high radial torques, the new SFERAX Type H.L. linear ball bearing is ideal for uses ranging from peripheral devices to assembly machinery to injection molds, as well vertical applications such as vertical presses — and more.
The SFERAX Type H.L. features a 100 Chromium-6 steel housing, hardened to 63 HRC, ground (lapped for quality grade A), a brass ball tray, and precision 100 Chromium-6 steel balls. The SFERAX Type H.L. is approved for wide temperature use, -30 to +200°C (without seals). Its three external grooves make mounting easy.
The SFERAX Type H.L. linear ball bearing is available in a variety of precision grades, including B.A./Medium Improved, A/Good, XA, and Z.A. It is offered for use with a wide variety of seals and shaft tolerances and fits. The new SFERAX HL linear ball bearing is immediately available.
SCHNEEBERGER Inc.
www.schneeberger.com
Filed Under: Bearing Tips
