    • On the Floor
  • Advertisers
    • PR Submissions
    • Eblast Submissions
Schreiner ProTech launches unique foam-based adhesive tapes
By Michelle Froese | March 18, 2020
Schreiner ProTech, a Germany-based provider of developing and manufacturing innovative functional labels, has developed a novel solution for bonding components typically used in the automotive and electronics industries.
Featuring foam-based adhesive tapes, Folding Frame Solution enables reliable, quality component connection
Featuring foam-based adhesive tapes, Folding Frame Solution enables reliable, quality component connection.
Known as “Folding Frame,” this patent-pending solution provides a more efficient and effective alternative to conventional conjoining methods — such as liquid gluing, bolting, soldering, riveting, single strips of adhesive tape, or even frames created from full-surface cutouts.
Across all industries, components made of diverse materials are bonded for purposes such as protection, sealing, and enhanced aesthetic appeal. However, these connections must be long-lasting and temperature-resistant. Conjoining such components requires precision to ensure parts are accurately and neatly connected for an ideal finish.
Adhesive frames created from full-surface cutouts are commonly used for this purpose, but can produce significant waste. The material is typically only available in single units or sheets, which can require costly automated systems capable of placing and processing each unit individually. Additionally, with manual processing the risk of faulty adhesive bonding is a factor.
By contrast, adhesive tape saves materials but, during manual processing, typically leads to small gaps or overlaps in corners. As a result, the component connections are neither watertight nor dust-proof. Liquid gluing is another method that can be used to connect complex geometries.
However, the curing times of liquid adhesives slow down the assembly process, and their flow behavior usually prevents accurate and clean adhesive bonding.
Benefits of the Folding Frame
With its foam-based adhesive tapes, Schreiner ProTech’s Folding Frame successfully meets industrial demands for fast-curing and clean adhesive solutions, and eliminates the complex cleaning requirements of liquid adhesives.
Thanks to the matching Folding Frame System, it can be precisely positioned to ensure the component’s subsequent functionality. The Folding Frame Solution is suitable for semi-automatic or fully automated processing of roll-fed materials, which saves time and costs, and reduces the risk of defects that may occur in manual processes. Due to the production of a foldable adhesive version instead of a frame created from a full- surface cutout, multiples can be achieved more efficiently and material consumption significantly reduced for sustainable, eco-conscious manufacturing.
Self-adhesive conjoining solutions also support the lightweight design trend to replace bolted, riveted, and soldered solutions. In addition to bonding and sealing, foam-based adhesive tapes make it possible to equalize uneven areas or height differences, as well as reduce noise. Schreiner ProTech, together with the Schreiner Services Competence Center, offers customized system solutions. The product solution and matching processing system are supplied by a one-stop shop.
Schreiner ProTech
schreiner-group.com
Tagged With: SchreinerProTech
  • Siemens aims for 80 percent automation in German plant
  • Humanoids building humanoids, and new robots for agriculture equipment in Kansas
  • Amazon takes on another industry: robotics
    • On the Floor
  • Advertisers
    • PR Submissions
