With more than 75,000 implemented, customer-specific solutions, SCHUNK has been developing and manufacturing hydraulic expansion arbors for high-precision applications in milling, hobbing, turning, grinding, assembly, inspection, and balancing for over 35 years. With SCHUNK, profit from the know-how of the world’s largest supplier and the market leader for hydraulic expansion technology … now with VERO-S Module Quick-Change capabilities.
There are many benefits to using SCHUNK Hydraulic Expansion Arbor with VERO-S Module Quick-Change system for cCustomer-specific clamping solutions, including:
• Top tooling change in seconds (which allows quick and easy flexing of machine)
• Rigid assembly with up to 25,000 Newtons of pull down force created by the VERO-S Module
• Ease of operation (VERO-S Module is Spring Clamp-Air to Unclamp)
• Maximum run-out and repeat accuracy of <= 0.005 mm (when used with 0.000 mm axial runout spindle)
• Excellent vibration damping
From the initial discussion through to integration of the finished clamping device in your processes, you will benefit from our customer-orientation and development expertise. By providing an individualized engineering design, we guarantee optimal adaptation of the clamping device to the workpiece and machine.
The post SCHUNK hydraulic expansion arbor with VERO-S module quick-change capabilities appeared first on Robotic Tips.
Filed Under: The Robot Report
