The new TTS Touchless Switch is a robust stainless-steel switch designed for indoor or outdoor public use to prevent the spread of pathogens.
The TTS optical ToF (Time of Flight) technology allows for precise programming of each individual switch. The standard detection distance is set at 60-0.1 mm. This detection distance ensures that wiping or cleaning the switch surface does not trigger a switching malfunction. The TTS technology is also insensitive to splashes, drips, rain or sunlight.
A momentary or latching version is available. The switch is bicolor ring illuminated red/green for optical feedback. Illumination supply voltage is if 5-28 Vdc. The TTS has a switching current and voltage maximum of 100 mA at 42 Vac/60 Vdc. Applications include automatic door openers in hospitals, airports and transportation facilities, as well as restroom facilities within these public places. Other applications include use as a photoelectric barrier.
The TTS has a product lifespan of more than 20 million switching cycles; a benefit of no moving parts. Impact resistance is IK09. It has an ingress protection rating of IP67. Mounting diameter is 22 mm and is by means of a nut with anti-rotation protection, allowing easy installation and substitution of same sized touch switches. Laser lettering and symbols available.
Pricing for the TTS starts at just under $40 each at 100 pieces, packaged in boxes of 10 pieces. The TTS Data Sheet and White Paper provide more information. Sample orders can be placed through the official channel.
For sales and product information, contact Cora Umlauf at (800) 848-2600 or by email at [email protected]
SCHURTER Inc., 447 Aviation Blvd., Santa Rosa, CA 95403, www.schurter.com
You may also like:
Filed Under: TECHNOLOGIES + PRODUCTS, Switches
