SCIGRIP is showcasing its SG100 Series methacrylate adhesives in Booth #1520 at the 2012 International Boat builders’ Exhibition & Conference (IBEX) in Louisville, KY.
The newly reformulated SG100 Series delivers superior adhesion properties, while requiring minimal surface preparation for bonding a wide range of materials used in boatbuilding and marine applications.”
SG100 Series are two-part methacrylate adhesives designed for application at a 10:1 adhesive/activator mix ratio, and feature a choice of either 15- or 40-minute working times, with fixture times of less than 30 and 80 minutes, respectively. The non-yellowing, UV-resistant adhesives are ideal for marine applications, with non-sag handling characteristics to facilitate application on non-level surfaces.
They can be used to bond composite materials; metals; or thermoplastics with a minimum of surface preparation to reduce labor costs and production cycle times. Adhesion properties of SG100 Series adhesives include a tensile strength of 2,800 – 3,200 psi (19 – 22 MPa); lap shear strength of 2,000 – 2,400 psi (13 – 16 MPa); and tensile modulus of 65,000 – 80,000 psi (448 – 552 MPa), measured at 75°F/24°C.
SCIGRIP Smarter Adhesive Solutions
www.scigrip.com
Filed Under: Adhesives • epoxies, Materials • advanced
