PEM® Types PF7M™ and PF7MF™ captive panel screws introduce two distinct mounting styles for permanent installation into thin sheets. Both types feature small, compact, and low-profile designs for limited access areas. The screws also have the MAThread® anti-cross threading technology that easily corrects off-angle installations, aligns components, and slides through clogged internal threads. Their Phillips recess allows for tool or hand operation.
Type PF7M screws install flush on the back side of panels as thin as 0.036 in./ 0.92 mm and are available in two screw lengths with thread sizes #4-40 through #8-32 and M3 to M4. They can install reliably into panels with hardness of HRB 80 or less or HB 150 or less.
Type PF7MF captive panel screws feature a flaring design for mounting closer to the centerline of the sheet. They install flush on the back side of panels as thin as 0.031 in./0.79 mm and are available in two screw lengths with thread sizes #4-40 through #8-32 and M3 to M4.
PennEngineering
www.pemnet.com
Filed Under: Fastening + joining, Screws • nuts • bolts • rivets
