SDP Offers a Wide Selection of Bearings
By atesmeh | July 29, 2013
Stock Drive Products (ISO 9001 Registered Manufacturer) offers a wide selection of bearings in many different styles to fit your application. Of particular interest are the A 7Y55… series of ABEC 3 ball bearings. These bearings are suitable for commercial applications that require low friction movement. They support both axial and radial loads with minimal play.
Both inch and metric size bearings are available. They come in plain and flanged styles and can be single or double shielded, if shielding is required. Standard options for lubrication include oil and both military and commercial grade grease, but other lubricants are available on special order to ensure your application needs are met. Static and dynamic load ratings go up to 1030 lbf and 1620 lbf, respectively.
SDP/SI is a leading manufacturer of small mechanical components, servicing a wide variety of aerospace, medical and commercial industries for over 50 years. Quotes, online orders, and 3D CAD Models are available on our updated estore at www.sdp-si.com/estore. SDP/SI offers over 130,000 small mechanical components, including gears, belt and chain drives, shafts, shaft accessories, bearings, couplings, universal joints, vibration mounts, miscellaneous components, hardware, gearheads and speed reducers, right angle drives, brakes and clutches, motors and gearmotors. For additional information about SDP/SI please visit www.sdp-si.com.
For additional details go to: http://www.sdp-si.com/product-announcements/ABEC-3-Ball-Bearings.htm
Filed Under: Bearings, Rapid prototyping
PCB mills
