Stock Drive Products/Sterling Instrument (SDP/SI) has launched a series of Integrated Motors to simplify motion system design.
Replacing multiple components with a compact all-in-one motor and electronics package, Integrated Motors simplify motion system design while providing many advantages. “Doing speed, position and torque closed-loop control with separate brushless motor and driver/controller technologies can be challenging,” said Jacques Lemire, Business Unit Director, Motors & Motion Control. “Our integrated motor controllers provide easier set-up, smaller and cleaner motion control solutions. By keeping the wiring from the motor to the driver short, integrated motor controllers are the perfect solution for reducing the communication time for the signals from the drivers to the motors.”
SDP/SI products are available with a wide range of standard features for easy integration intended for industrial automation applications. The Integrated Motor Controllers include state-of-the-art brushless servo motors with 4,096 line encoder and CANOpen network protocols in an intelligent plug-and-play package. The high-performance 60-mm NR5-LD60 series incorporates motor, encoder, and drive with smooth and quiet sinusoidal commutation with Field Oriented Control (Vector Control) into a compact unit. The NEMA 23 NH5-DM series is an economical turn-key solution to speed and torque analog motion control. Eliminating multiple components, connectors, cabling, and labor can save significant cost.
For more information visit www.sdp-si.com.
