    • On the Floor
Sealed Industrial Pressure Sensors
By Design World Staff | December 15, 2008
Moorpark, CA ‚– Kavlico has launched a line of sealed industrial pressure sensors that incorporate a stainless steel diaphragm in an all welded 304L stainless steel housing making them well-suited for hostile environment applications. The sensors utilize Kavlico‚’s oil-filled piezo-resistive (PRT) sensing technology along with a state-of-the-art ASIC. Rugged by design, the sensors are capable of operating with a wide array of fluids and gases that are compatible with stainless steel.
Pressure ranges are available from 0-100 through 0-5,000 PSI absolute or sealed gage for the models P251/P251R and 0-6 through 0-400 Bar for the models P250/P250R. The P250/P251 operate on a 5 Vdc power supply and provide a ratiometric 0.5 to 4.5 Vdc linear amplified output proportional to pressure while the P250R/P251R have an internal regulator and operate on 9 to 32 Vdc while providing a regulated 5 Vdc or 10 Vdc linear amplified output proportional to pressure. Each sensor is temperature compensated and exhibit excellent EMI/RFI rejection capability. The high reliability sensors have an over-pressure capability of 2X FSO (Full Scale Output) and have been designed to operate in situations with large over-pressure spikes.
Typical industrial applications include refrigerant control and recovery, pumps and compressors, process control, water management, autoclaves, hydraulic systems, and test and monitoring equipment.
A wide variety of 12 standard electrical and 10 standard process connection options allow the sensors to be configured to meet each end-users application-specific requirement.
www.kavlico.com
Filed Under: Sensors (pressure), TEST & MEASUREMENT
  • Siemens aims for 80 percent automation in German plant
  • Humanoids building humanoids, and new robots for agriculture equipment in Kansas
  • Amazon takes on another industry: robotics
    • On the Floor
