    • Subscribe!
Sealevel’s SeaPAC HMI delivers RISC computing power
By Patrick Curran | October 21, 2014
The SeaPAC R9-8.4 combines a powerful RISC-based embedded computer with a bright 8.4” TFT LCD to create a wide-temperature, ruggedized, flat panel computer perfect for a variety of HMI and control applications. Featuring LED backlight technology, the system offers an impressive extended operating temperature range of -30° to +70°C with no heaters or cooling fans required.
sealevel-hmi
Powered by a 400 MHz ARM9 microprocessor, the SeaPAC R9-8.4 is available with 128MB RAM and 256MB Flash memory for maximum performance in embedded systems. Standard I/O includes Ethernet, serial, USB, and digital interfaces. For intuitive operator interface, the system includes a resistive touchscreen that is suitable for a wide range of industrial environments and applications. The SeaPAC R9-8.4 is intended for panel mounting and provides NEMA 4/IP65 protection from sprayed liquids.
Local or remote I/O expansion is available using Sealevel SeaI/O modules. Choose from a variety of I/O configurations including optically isolated inputs, Reed and Form C relay outputs, TTL interfaces, A/D, and D/A. The SeaPAC R9-8.4 connects to SeaI/O modules via the system’s RS-485 expansion port and communicates using Modbus RTU.
To provide the fastest time to market, the Windows CE 6.0 BSP binary and low-level drivers for system I/O are included. Additionally, the SeaPAC R9-8.4 software package is equipped with the Sealevel Talos I/O Framework, which offers a high-level object-oriented .NET Compact Framework (CF) device interface. This interface provides an I/O point abstraction layer with built-in support for easily interfacing the system’s I/O. Linux support is also available. The SeaPAC R9-8.4 (Item# S95100-8R) is available from $1,599.00 in low quantities.
Sealevel Systems
www.sealevel.com
Filed Under: Factory automation, HMIs • operator interfaces • monitors, Industrial computers
Tagged With: sealevel
Dual high-temperature Cabinet Cooler systems for large enclosures
    • Subscribe!
