MIDDLETOWN, Pa. ‚– Phoenix Contact introduces the second generation of STEP general purpose power supplies. Expanded voltage and current ranges make the redesigned STEP series well suited for small load applications where size is a premium.
The new STEP power supplies feature a voltage versus current characteristic output. Upon heavy load demands, the power supply provides constant current output. This is ideal for starting lamp loads or capacitive loads. Some STEP models also have adjustable output voltages, allowing for lead length compensation.
With its unique DIN rail clip, the STEP can be mounted either on a rail or in a panel. STEP power supplies are ideally suited for any location that requires a compact and reliable power supply.
Filed Under: Power supplies, ELECTRONICS • ELECTRICAL
