    • On the Floor
Selco’s 1/2-Inch Disc Thermosats
By Design World Staff | December 9, 2008
ANAHEIM, CA ‚– Selco Products has introduced the Precision Differential Thermostat Series for extremely accurate temperature control. Featuring tight differential between 9‚°F and 14‚°F (5‚°C to 8‚°C), these ‚½-inch Automatic Reset Disc Thermostats are suitable for temperature control in heaters, commercial food equipment, spas, and medical equipment.
The new Precision Differential Thermostats are available with Selco‚’s Open on Rise (OA) and Close on Rise (CA) configurations. Features include a Phenolic Body, setpoint between 50‚°F and 203‚°F (10‚°C, 95‚°C), and a highly reliable switch that utilizes a temperature sensitive, snap-action bimetal disc, electrically isolated from the switch. Contacts open or close on rise when surface or ambient temperature increases to the set point of the calibrated bimetal disc. The calibrated fixed disc is mounted adjacent to the monitored surface, providing a rapid response to temperature changes.
Silver contacts are rated to 15 amps at 125VAC (10 amps at 250VAC) and gold contacts are rated to 1 amp at 30VDC. Thermostats may be factory calibrated at any temperature between 50‚°F to 203‚°F (10‚°C to 95‚°C) and specified with a wide variety of mounting options and terminals. Value added services provide additional customization with soldered wire leads, connectors and epoxy overmolding. Ratings and approvals include UL, CSA, VDE and ROHS compliance.
www.selcoproducts.com
::Des
ign World::
Filed Under: Sensors (temperature), TEST & MEASUREMENT
  • Siemens aims for 80 percent automation in German plant
  • Humanoids building humanoids, and new robots for agriculture equipment in Kansas
  • Amazon takes on another industry: robotics
    • On the Floor
