GERMANTOWN, WI – UL and cUL Certification is complete for 27 models within WAGO Corporation’s EPSITRON family of advanced power supplies. Certification applies to select models within the EPSITRON Electronic Circuit Breaker, PRO-Power Supply, Uninterruptible Power Supply and Redundancy module lines.
787 Series EPSITRON Electronic Circuit Breakers (ECBs):
4-channel ECBs separately protect up to four current paths (up to 10A at 24VDC max each) for power supplies without “topboost.” Ideal for multiple loads from a single power supply, ECBs independently program load-appropriate current ratings and trip times. ECBs also offer remote resetting of tripped channels.
787 Series EPSITRON-PRO-Power Supplies:
1- and 3-phase Primary Switch Mode PRO Power Supplies process power peaks in systems with high-output requirements. Features: 93% efficiency, PowerBoost and TopBoost functions; select models also offer free configuration/monitoring software and Line Monitor capability.
787 Series EPSITRON Uninterruptible Power Supply (UPS):
UPS modules shield complex automation systems and components from common disturbances (e.g., voltage fluctuations, harmonic distortion and outages). Features: free configuration and monitoring software and LCD/keypad and RS-232 interface.
787 Series EPSITRON Redundant Modules:
The 787 Series redundancy modules safeguard two power supplies that are parallel-connected, providing system redundancy or additional power.
WAGO
www.wago.us
Filed Under: Factory automation, Electronics • electrical, Power supplies
