Self-cleaning, maintenance-free ionizers remove static electricity
By Mary Gannon | March 3, 2021
KOGANEI International America Inc. has introduced the DTY-ELF14HC multi-function, self-cleaning ionizer for easy and efficient static electricity removal. This high-performance AC (200 Hz) system provides excellent ion balance (±5 V) and steady long-term elimination of static electricity over an extensive range. The unit’s automatic cleaning function removes dirt on the discharge needle with a built-in brush, so no maintenance is required. (The discharge needle is automatically cleaned once every 24 hours when power is on, or may be cleaned on command by pressing the auto-cleaning switch.)
KOG530_KOGANEI-DTY-Series_72-dpi-static-maintenance-free-ionizerKOGANEI’s DTY series is ideal for any application that requires a static-free environment, such as workbenches and circuit board assembly areas, or to remove static from packaging film, plastic containers, and parts.
Other highlights include:
  • Airflow volume control for easy adjustment
  • Extremely low ozone production (less than 0.004 ppm)
  • Balance indicator for confirmation of positive/negative ions
  • Alarm output function
  • Available in steady flow, cross flow, wide area, and overhead model configurations
www.koganeiusa.com
Filed Under: MANUFACTURING, MORE INDUSTRIES, MOTION CONTROL
Tagged With: koganei
