PEM Type PFC4 self-clinching stainless steel panel fasteners permanently install flat on one side of thin stainless-steel sheets. Made from 400 Series stainless steel for use in stainless sheets up to HRB 88 hardness on the Rockwell “B” scale, they have corrosion resistance comparable to zinc plated steel. The fasteners meet UL 1950 service area access requirements to enable subsequent access to an assembly.
Ideal for attaching stainless sheets from .060 in. (1.53 mm), they use a captive-screw construction to minimize hardware, promote quick installation, and eliminate loose parts falling out and damaging components. The fasteners, with complete spring-loaded assemblies, come in variable screw lengths and thread sizes of #4-40 through #10-32 and M3 through M5. All are RoHS compliant.
Penn Engineering
www.pemnet.com
:: Design World ::
